The RS is currently undergoing major surgery, to be more specific, it's getting a T5 and an 8.8 rearend. While still neck deep in this project, I have few thing I need help with:
*I have a double hump crossmember from my previous 90 GT, i was trying to put it on and it seems like its putting the tranny high enough to hit the floor board, is the problem the member, or the trans itself which is out of an 89 GT?
* The T5 seems to be a tad futher forward than the SROD judging from the floorboard hole, did any of you guys who converted had to make the hole larger?
* I also have the stock "headers" from the 90, would this work if I was to take off the flapper valve on the driver side manifold?
Any help would be very much appreciated. Thanks guys!
