On my Edelbrock rpm heads, the bolt hole that holds the alternator stud has a threaded insert in it. When I removed the stud from the head, the insert came out with it. I've been trying to remove the insert from the stud so I can screw the insert back into the head where it belongs. So far the stud and insert have defeated all my efforts.
Here's the insert and stud in question:
Here's the hole in the head it came out of:
I thought if I put two nuts on the insert, then tightened them against each other, and put them in the vise, I could turn the stud out. I thought I was getting it till I noticed that the vice-grip was merely slipping on the stud, but not turning it. So I used a small pipe wrench on it, which gripped the stud, but no matter how tight I made the nuts, the insert would turn out of the nuts instead of the stud turning out of the insert. Liberal application of liquid wrench did not help. I was forced to retreat and regroup today, but tomorrow I intend to rejoin the battle with my buddy the torch on my side.
Anybody have any thoughts on this? Is it possible to just buy a new insert? I don't see anything like that on Edelbrock's website, where would I get one?
The threads in the head where the insert goes look to be fine, and I would just screw the stud and insert back in together if I was reusing it, but I'm going to a different set of heads, and intend to ebay these. I don't want there to be any problem with them that will hurt the resale value.
Any help will be appreciated.
