Results 1 to 7 of 7
    Dec 2005
    portland oregon
    Default fuel gauge reading wrong
    Ok so Iadmit it , i sinned lol. I swapped the interior in my 86gt to all black 87-93 but now im having probs with the fuel gauge reading wrong. I never swapped out to a newer sending unit, and when i put 5 gallons in there itll read 1/8th tank which I know is wrong. the gauge on my old style instrument cluster worked great with the sending unit thats in there right now. Its the sending unit isnt it??
    thanks
    Drew
    Do a search for fuel sender here, this has come up before.
    Marc aka tripice351. 84.5 GT-350 2.3T. looking for another coupe.
    Dec 2005
    portland oregon
    so i found these resistance specs
    79-86: 8-12 ohms full, 60-86 ohms empty
    87+: 145 ohms full, 22.5 ohms empty
    Another thing to note is that if i fill the car up then the gauge reads full, maybe my sending unit has a dead spot......so frustrating
    Dec 2005
    portland oregon
    I did a search and some people say that it should read backwards, which is not happening in my case and some other people have said that in 90-91 the sending unit is dif than the 87-89, my harness is from a 92 5 liter. thatd make sense because the instrument clusters and harnesses are dif for 87-88, 89 and 90-93
    The later aeros have an "anti slosh" module behind the dash somewhere. It's often the culprit of a non functioning gauge.
    FEP Member rbmead86's Avatar
    Dec 2004
    Lithia Springs GA
    "Bump"
    Im having the same Problem.
    Have You Registered your GT?
    www.mustanggt.org
    1986 Mustang GT Vert
    1985 Ford LTD SSP
    1977 MGB Vert
    Quote Originally Posted by D347643 View Post
    I put those specs up. The resistance vs tank level is essentially reversed for 79-86 vs 87+. The sender AND gauge must be from 79-86 or 87+. You cannot mix them. The anti-slosh module is basically a chip that 'averages' the instantaneous resistance output from the sender so that the gauge readings dont fluctuate. Averaging algorithms are very common is instrumentation.
    Paul
    1978 Mercury Zephyr 4-dr / Holley 600 vac sec carbed 1989 5.0L HO with Edelbrock Performer intake / MSD-6A / T-5 / 8.8" rear 3.27:1 / Mustang 5.0L brakes, suspension, steering / Dual exhaust / Mustang 10 hole wheels / P225/60R15 Goodyear Eagle TR
