Page 3 of 7 FirstFirst 12345 ... LastLast
Results 51 to 75 of 162
  1. #51
    man i wish i had the time and talent to do that
    <<1985 mustang gt, 5 speed t-tops.
    The Objects In The Mirrors Are Losing.......
  2. #52
    Great Thread!
    "Remember.....Wherever you go there you are."
    GearedUp
    James
  3. #53
    Nov 2006
    dearborn,michigan
    you are a pro and if you're not already you should quit your day job and open a bodyshop.you can find the front and rear taillights from a website called www.ascmclaren.com i don't think it would look cluttered at all.great job
  4. #54
    FEP Super Member 93-331-29PSI's Avatar
    Dec 2005
    Chesapeake VA
    Quote Originally Posted by capri debris View Post
    Are those parts painted or coated? Looks nice, I can't wait to see this car when it's done.
    I thought about stripping and painting the underside of mine, but since I don't have any rust I think I am going to be cheap and have a thin coat of line-x sprayed instead.
    Keep up the good work!!!
    83 GT Turbo
  5. #55
    FEP Power Member tman1257's Avatar
    Jan 2006
    yankton, sd
    Quote Originally Posted by 93-331-29PSI View Post
    Never thought about the Line-x. Sounds like a good idea.
  6. #56
    Sep 2005
    Pensacola, Fl
    Your parts are looking good; the car is looking good and keep this up!
  7. #57
    Made some progress with the rear axle...
    The big 8.8 with 20+ years of use and rust on it.
    So I took it apart and sand blasted the whole thing.
    Then I painted it with "Chassis Black" so it will never rust again.
    Then I finish coated it with Gloss Battleship Gray.
    And I also completely re-built the differential. New clutches, bearings, races, seals and a set of 3.73 gears! Moser axles are waiting to be put in.
    '86 Capri 5.0, black with charcoal interior, 5 spd, fully restored, mildly modded.
    '86 Capri 5.0, white with black interior, C4, rotisserie restored, heavily modded.
  8. #58
    FEP Super Member Shadow 1's Avatar
    Mar 2007
    Gresham, OR
    One word says it all, "WOW".
    Did you use a rattle can or brush for the paint in the engine bay and underside?
    -Kal
    "One man can make a difference." -Wilton Knight
    84 Mustang T-Top
    THE WRAITH
    Women are like cars, sometimes you find one you fall in love with, and sometimes you end up with a lemon.
  9. #59
    Sep 2005
    Pensacola, Fl
    Pretty stuff! I like the look of your ride.
  10. #60
    Quote Originally Posted by Shadow 1 View Post
    Both... after taking it all down to bare metal I used a brush on rust preventive paint called "Chassis Saver." Then I put 2 coats of primer, wet sanded it and rattle can gloss black as a finish coat. The previous pictures of the underside are of it in primer because the finish coat turned out so shiney that it's hard to get a good picture of it due to the reflection... but here's the best I could get.
  11. #61
    awesome work, for white it really looks sharp on that car
    1998 SVT Contour Daily Driver- K1 Racing Wheels CAI
    1985 Mustang GT T-top Black
    Freshened/Blueprinted 302-Heavily Worked GT40 Heads SS valves and Heavy Duty springs-1.6r Crane Cams RR-Custom Grind Comp Cam-Wieand Intake-Edelbrock Carb-MSD-King Cobra Clutch-World Class T5-Cobra 4whl Disc-31spl 4:10 rear-Longtubes-Strange 10Ways-Mac Exhaust with 3" Rolled tips-
    1984 RS Turbo Capri 100% Show car
    1982 Mustang GT
  12. #62
    Mar 2007
    Gresham, OR
    Looks really good. What kind of primer and rattle can black did you use? I gotta do this to mine this winter, I just hope the paint can dry in an unheated garage.
    -Kal
    84 Mustang T-Top
    THE WRAITH
  13. #63
    Looks amazing sofar! seems like a ton of effort and time but I'm sure it will totally be worth it!
    1980 Mustang Ghia 3.3 4spd
  14. #64
    I bought a new AOD from Performance Automatics. It's the Competition series and I had them install the "H" valvebody, which means it is rated at 550hp and I can shift it without doing the 1-D-1-D shuffle. I can hold each gear to redline and when I lift it will go into OD or I can put it in OD and let it shift on it's own if I want. With my new B&M Hammer shifter, it'll be almost as fun to drive as a 5 spd. It arrived painted metallic blue... I have no idea why, but I planned on painting it anyway, so no biggie.
    Here it is painted blue...
    After I scuffed the blue paint, I primered it...
    Here it is painted Ford gray...
  15. #65
    Sep 2005
    Pensacola, Fl
    More pretty stuff. I don't quite understand the blue paint either, but hey......... Nice progress so far!
  16. #66
    More progress on the rear.
    Got some new Moser axles.
    I pressed longer lug studs in for the slicks.
    New wheel bearings.
    New axle seals.
    A pic of the axles installed.
    New stainless brake lines and a new Mac differential cover.
  17. #67
    Mar 2007
    Gresham, OR
    Looking really spiffy. What kind of primer and rattle can black did you use to paint the underside? I gotta do this to mine this winter, I just hope the paint can dry in an unheated garage.
    -Kal
    84 Mustang T-Top
    THE WRAITH
  18. #68
    I've gone over how the underside was done earlier in this thread... it was a several step proceedure. Not very fun to do, but well worth it.
  19. #69
    FEP Senior Member captnet's Avatar
    Jun 2007
    Quakertown, Pennsylvania
    Excellent! The rear and trans on my restoration will have to wait. Thanks for the descriptive detail.
    85 Capri 5.0L Sport Package (purchased new)
    03 Jeep Grand Cherokee 4.0L Laredo 4x4
    -- The simple believeth every word: but the prudent man looketh well to his going.
  20. #70
    May 2002
    Wareham, Massachusetts
    It's looking fantastic! I can't wait to see it all done and see the pic's at the track when you go to race it. What kind of times are you hoping for?
    Pete Slaney
    1979 Mustang Cobra
    347/T-5/4.30's
    420 rwhp/380 rwt (New Motor)
    11.49 @ 121.86
    306/T-5/4.30's (Old Motor)
    307 rwhp/278 rwt
    12.38 @ 111.38
  21. #71
    FEP Power Member cjmuscle's Avatar
    Aug 2007
    pembroke,ma
    WOW!!! What a transformation, your car looks great. Keep showing us those pics in progress, its nice to see these foureyes being saved takes alot of time and dedication.
  22. #72
    Quote Originally Posted by Hissing Cobra View Post
    Thanks, Hissing Cobra. As far as what I'm hoping for at the track... 11 anything. Just as long as I'm in the 11's. LOL.
  23. #73
    looks great, its hard to belive how much work you have put into it
    85 coupe
  24. #74
    Sep 2005
    Pensacola, Fl
    Keeping it 4lug I see? Your ride is really looking good. Keep this up and you will have a mighty fine ride!!
  25. #75
    Very nice!
    1981 Capri-Black magic-5.0/SROD/8.8
    1993 Mustang LX -2.3/T-5/7.5
    1988 Thunderbird TC - 2.3T/T5/8.8
    1975 F-150 4x4 -5.8EFI/M5OD/NP205/9"
