And all I can say is WOW.
A little background. This motor has in the neighborhood of 9-9.5:1 compression because someone installed an N/A head on it. So for the entire summer the setup was 6* base timing, 8-9 PSI max boost, and 91 octane from town.. In this trim, as long as it was cool out, it would pretty much hang dead nuts even with a stock 4.6 GT of the 99-04 variety. Once it warmed of after a few hard pulls it was ping city on the 91 octane.
This fall I started using Sunoco 94 Ultra and the pinging went away. Soooo.. my buddy who bought my old T Type, gave me my old Turbonetics Dial a bost in car boost controller. Wanting a bit more passsing power without having to basically drag race my way around cars, I installed the controller and set it to 12 -13 psi, on the 94 octane, and didn't touch timing.
My first real test was this morning in the cool dry air around 4 am. Had all my tools in the trunk, and a passenger [both of us are around 400 LBs together] and I drove for a few mins to let it warm up, and I turned onto a long desolate road and got a slow roll on in 1st... matted it... boost wound up, and it obliterated the rears.... and tached out... snagged two quick, and it sorta fishtailed, and wheelhopped mildly up to about 45 MPH then hooked for a split sec at the top of 2nd and at 50 MPH, I bagged 3rd and it pulled out to 85 MPH.... FAST.... it was a whole different car.
These huge gains from only 3-4 psi must be due to two things, it was running pig rich on the lower boost, BUT adding 3-4 PSI on the higher compression motor it reacted much differently then when I have added 4 psi on my SVO. This thing diesn't even have a ported E6 and has a crush bent stock downpipe 2 1/4" diameter..
I can say with out a doubt, that when I build a strong shortblock for the SVO or Capri, whichever, seeing as how I run race gas anyways, it's going to be a 9.5:1 motor. [with good rods, pistons, arp stds etc...]
That little 2.3 had to be making some good HP to haul 3700 LBs up the street like it did this morn..
