Page 58 of 58 FirstFirst ... 848565758
Results 1,426 to 1,448 of 1448
  1. #1426
  2. #1427
    Sep 2010
    Lexington, MA
    From Post #1337
    Making note on calendar for the year 2026
    Only five years to go Joshy!
  3. #1428
    Mr Joshua, do your marchals have the cat heads missing? If you need a set, let me know. Amazing car!
    1984 T-top GT
    1984 20th Anniversary GT350 Convertible
    Factory Five 427 Roadster http://www.stangnut.com
  4. #1429
    FEP Super Member Mr Joshua's Avatar
    Dec 2005
    Spencer, Massachusetts
    Quote Originally Posted by fiveliter8 View Post
    I have two sets of Marchals, one white and one black, both have cathead's.
    I can't complete with Jeff's collection though, he might still be the Marchal master.
    Thank you!
    83 GT w/ T-Tops (JeffCleaned)
    2021 Turbo Blue Audi S5
  5. #1430
    Dec 2005
    Quote Originally Posted by Capriman86 View Post
    BUMP....anymore?
    Be prepared, I believe I have close to 190+ pictures to upload and write captions for on here.
    I have a lot of catching up to do and have made some important progress while re-establishing my motivation.
  6. #1431
    Welcome back, Mr J. Your car is awesome����.Real people do Real things and Have Integrity. You taught me that. Your car is living Proof.
  7. #1432
    Quote Originally Posted by Mr Joshua View Post
    Hurry up, I cant wait any longer. I missed this car.
    I would love to see the progress.
    1984 Mustang LX
    302, Holley 4bbl 600 vac sec
    B&M C4 R servo
    Shorty Headers
    MSD Box and Coil
    Scorpion Roller Rockers 1.6
    Crower Cam 472 112 seperation
    Chetah Shifter
    Performer RPM Intake
    Carter Electronic Fuel Pump
    Accel Eletronic Dizzy
  8. #1433
    Hi Mr Joshua, welcome back. I've read through this thread in the past, but spent the last couple mornings going through it again. This is quite an impressive project and you've done some awesome work. Hope to see your updates soon.
    Thomas
  9. #1434
    Dec 2005
    Default The Resurrection
    I'll start almost where I left off with the backing plates being primed for a fitment trial.
    So, with that done I decided to take the subframe on a trip as the A-Arm mounting holes were certainly not lining up with the new Delrin bushings.
    Yes, this is going to be a long drawn out tease, maybe one picture a day till I'm caught up.
  10. #1435
    Sep 2010
    Lexington, MA
    Josh, looks like it was Bright Red '27' from the factory, Black interior too. Update when you can
    Last edited by Bryan Knebworth; 04-21-2023 at 06:40 AM. Reason: Celts are winning, nice
  11. #1436
    Jul 2005
    Medicine Hat, Alberta,Canada
    The Mr Joshua thread lives!! I wish I could say the same as my Ttop coupe
    Sent from my motorola one 5G ace using Tapatalk
  12. #1437
    Dec 2005
    Seeing's how I missed a day of posting pictures to bring yall up to date I suppose I should post two today...
    Time to get to work!
    Let's take some measurements to find out where to start hacking away at!
    To the CMM for the datas!!
  13. #1438
    Dec 2005
    First thing was to take a couple points with the CMM to verify how far out of alignment the holes were, even though I could tell by eye.
    So I had to level it first on the inspection table to take those measurements.
    It actually leveled out quite nicely at around .020/.040ish with shims, using 3x2x1 machining blocks and a few 4x4 1/4 wall square tube pieces.
    Here's how they looked on the screen. lets just say the numbers we not forgiving, I'd show the comparison with the end result, however it doesn't translate well without the 3 pages of coordinates from the CMM and the software to interpret it..
  14. #1439
    Dec 2005
    Decided at that point to work on the brackets a little more and think about the best way to get some progress.
    Not too shabby I must say.
    I should have known better than a metal fabrication company to have a simple thing like file handles, so I made my own.
  15. #1440
    Dec 2005
    So, now to find the lesser of two evils so I'm not filing forever.
    This looks a little more manageable.
    If anyone else is planning on doing this, DON'T unless you have all the time in the world as this took measurements from 5 different frames to accomplish.
    Note: Put the stock bolts in the REAR LOWER CONTROL ARM HOLES WITH THE ARMS IN to make this process easier.
    These frames were setup on a factory jig and welded, the tolerance are LOOOOOSE even by factory "standards"....
    Pin Gauges & Time help immensely, this took about a solid week of lunches and break times at work to accomplish this.
  16. #1441
    Dec 2005
    It's back up!!!! <3
    Now to weld up those ovals now that the precision filing is done!
    Good ole Sparky!!
    Now to put some paint on it, how's my "quality" mask job?!?
    All set and ready for the ride home!!!
  17. #1442
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Sexy!!!
    '85 GT
  18. #1443
    Nice work!!
    Thomas
  19. #1444
    Nice job!
  20. #1445
    Dec 2005
    When last we left our lame horse in the stable she was missing her back legs..
    How about we fix that up.
    Now to check how well the brackets fit... tight!
    Check those plate holes, dimensions, etc...
    and send it with no fear!!!!
    Wango bango, side 1
    Oingo Boingo, side 2
  21. #1446
    Dec 2005
    Now rolly rolly the frame to its forever home!!
    Time to get out some elbow grease and cheater bar and send those bolts hooooome!
    Almost up to date, more fun stuff soon......
    In process inspection.... glad he wasn't too rough..
  22. #1447
    Great progress! Keep it up!
    OT: What's the crawler tractor to the left in the last pic?
    Thomas
  23. #1448
    This is amazing. Kudos on taking this on! Can't wait to see the finished product!!
    Had ~
    '81 Mustang Ghia Hatchback, red, 4-cylinder, 5-speed, slow, but looked great!
    Have ~
    '83 Mustang GT Hatchback, white with black, stock 5.0, 5-speed, T-tops, dual exhaust
