Perhaps change your driving habits. That looks like a case of abuse to me
81 CAPRI Best pass: 9.39 @ 142 with 1.25 60 ft.
*******Naturally aspirated 408W*******
or 9" rear end
82 Capri RS, 5.8L, solid drop mounts, areomotive fuel system, 3" exhaust, ROD six speed, MM torque arm suspension, "mathis" 90 k-member, 04 cobra control arms, h&r springs, koni shocks, m-2300-k, caged, battery relocate
Were the bolts pulled out of their threads or broken off? If the caps were the cause of the breakage then a set of billet ones would prevent that in the future.
Are you sure it's not a 7.5 or are you making 700 hp to the tire.
Worlds fastest 357 c.i.d.,1983 Crimson Cat,Mercury Capri RS with one Holley Dominator,One nitrous system,Turbo 400,Nine inch,All steel and glass,except hood,95% stock floor,Almost all stock interior(8.31 166)Under Reconstruction! 25.5 Complete now!
1978 Ford Fairmont Stationwagon,393 Windsor,OTMC,Turbo-350,8.8 31 spline axles,steel spool,C-Clip Elim,T/A cover,4.30 gear,MM Adj.Lowers,Baseline Pro-launch#2,Anti-roll bar,UPR K-member,A-arms,Coilover kit,Manual rack,Bumpsteer kit.Engine complete 648hp, 508lbft tq.93 octane N/A.
Originally Posted by todd scribner
I was thinking along the same lines myself.
Blowing up an 8.8 is quite an accomplishment.
2R '85 GT 'vert - VIN code M fuel injected 5.0 HO
The greatest discovery of my generation is that man can alter his life simply by altering his attitude of mind.
- William James
yeah really, i've got like a hundred 1.5 60fts on my 8.8 with no girdle.
thats impressive damage!
All I can say is WOW! How did you manage that?????
Justin
1985 Mustang GT 5.0 CFI/AOD (originally)
Now: 306, AFR 185s, Edelbrock Victor Jr. 302 Intake, Pro-Systems 4150HP, FTI/Ed Curtis custom cam, 170amp large case 3G Alternator, PA AOD with Silverfox SPT-MAC valve body, 3500rpm Stall, FRPP Aluminum Driveshaft, MM C/C plates, Tokico HP's, MM full length SFC's, SN95 Cobra brakes front and rear, 31 spline Fox length 8.8" with 4.10's, MM rear lowers and FRPP uppers, a few other MM suspension goodies, Jet Hot ceramic coated FRPP shorties, Pypes X-pipe, SpinTech Pro Streets and some other go fast parts.
1984 Mustang LX 5.0 4bbl/T5 (Sold)
LS swaps are the hair implants of the car world. Sure the owner is proud, but everyone else is laughing.
A 351w, a carbon kevlar clutch, and a bad control arm bushing. That cap broke across the bolt holes, and the bolts in the other cap bent.
go with a 9 inch rear with reinforcements, keep your tires, traction isnt your issue :P
83 Mustang GLX conv (in sonic blue)4.3/SC -coming soon! "Project Baby"
1988 Lincoln Town Car Limousine, Crafted by American Custom Coach Works- "Project Bertha"
proud member:
10 Hole Mafia
Anti-cowl club
Bent Six Bastards, lol
Wow dude, 8.8"s are near indestructible. You broke it like a twig.
1990 Mustang LX 5.0 - Ran into a tree (fixed!)
2005 Ranger XLT 4x4 - Daily Driver/Tow vehicle
1992 Mustang LX 2.3 - MPG baby yeah!
1994 Explorer - Fix 'n Flipper
Something wasnt right in that rear end. I have seen those 8.8's withstand 800+rwhp verts launching and never break like that.
"Sometimes the "majority" only means all the fools are on the same side."
2004 F-150- RC SWB 5.4 Vortech Supercharged
1984 GT-350 - EFI, Hellion Turbo, NX
1979 Indy 500 Pace Car- Money Pit
Originally Posted by FATHERFORD
I agree...something was wrong to make that happen. I go 1.25 60 fts and have never seen one like that...it wasn't from too much power.
I think the shock load from the axle hop did it. The wheel spinning freely and then taking load repeatedly for a couple seconds, plus the fact that clutch wouldn't slip and the u-joints wouldn't snap meant that something had to take the brunt of the force. As odd as it sounds, I'm planning on making a driveshaft loop and using cheap u-joints, just in case. If they do break I could replace them with a simple tool set and a little improv. That is, until I drop some money on nice gears and axles
Hey deleted...I read through my last post and it kinda made me sound like a dick. I didn't mean anything by that.
