didnt see anything
didnt see anything
Stable:
03 DSG GT, CAI, EXHAUST, TUNE, BLACK 03 COBRAS, Best ET: 13.98 @ 99.85
93 Strawberry LX Coupe.. roller..... for now.........
Not Likely to be Resolved? HAHA
86 LX Coupe 4E
85 SVO Hertz 4E
85.5 SVO 2R orig owner
86 SVO 7B
66 Fastback
55 Willys Jeep Overland Wagon
67 Cougar
85 Jalepeno Red GT
85 Bright Red RS
88 Smoke Grey GT Hatch
88 Bright Regata Blue GT Hatch
89 Bright Regata Blue GT Vert
2007 SL55 - Capri Blue - Leather, 487/560 WHP/WTQ at 13.5PSI
I know Mike (negsum) brought this up a while back about the louvers. This site is probably incorrect as 'FOXCHASIS' pointed out in the LL vs NLR code....
http://cma.itgo.com/news10v4.html
The question I have is - could you physically order a car with louvers or were they just a dealer bought item that you installed once back at the dealership. If you could in fact order them with a car, it would be intersting to see a factory ordered louvers car's buck tag.
I just don't know if you could actually order louvers and was that part of a factory build process instead of a dealership aftermarket ford item that was installed after the fact?
It would be intersting to see some build sheets with the NLR vs the same kind of car with no NLR. Mike's (negsum) car and mine are practically identical as Mike pointed out in one of his first posts on this thread except for the NLR tag, but I cannot access the car at this time to look for a build sheet. i think the only differenct in my car vs. Mike's is that mine has a factory sunroof which has nothing to do the NLR code from a previous post above. If I have time, I will also check my other 85 and 86 capri's soon.
Jason
maybe only the solid roof cars...Non Leaking Roof..lol
I do like Kens answer too....Not Likely to be Resolved?
Original Owners Club
Please post your name and ride in here:
http://vb.foureyedpride.com/group.php?groupid=3
Louvers were a factory option, hence the "LL" on the Buck Tag. The Buck Tag is what the assembly line workers use to put the car together. And the Build Sheet too.
If a dealer or owner installed something it wouldn't be on the Buck Tag or Build Sheet. Or the VC Label.
Louvers were not available on '83+ Capris or '85+ Mustangs. Why would there be a code on the Buck Tag for an option that was no longer available or installed at the factory?
I'm wondering if it may be some kind of an internal processing code and not necessarily something related to the actual car itself?
When I visited the Hapeville plant here in Atlanta the main body sections were built in sub-assemblies in different departments / areas. They were then brought together and assembled into the main body structure at the "real" beginning or the production line.
From there the hood, doors, and trunk were attached coming in from their respective areas prior to the primer dip tank.
Maybe something like Normal Line Release? Since the core support / buck tag is attached as the first way to identify the assigned VIN to that specific body shell, which then gives color and options, it may dictate an order sequence?
Having a number associated with it my be a shift ( day / night / weekend ) identifier?
From my experience as Production Control Manager when we released work orders to the plant we built a "traveler". It was the primary envelope which held the work order itself along with order specific packaging labels and any special customer required paperwork / forms.
As the order "traveled" through the steps in production each department added their required paperwork / information. The work order was a multi-part form and each department retained their page for internal record keeping. Since we were building aircraft parts it was a redundant feature for our required lot traceability / quality control.
In the case of our cars we have the build sheets that are quite often left in the car in various locations. The build sheet is also just one page of a multi-part form so there was obviously other internal paperwork that was retained by Ford for each vehicle produced.
I guess I'm just thinking out loud. My basic point is that all the data on the buck tag may not be vehicle specific.
Someone like Kevin Marti may be able to help. But then again he is having trouble deciphering the internal Ford paperwork trail now himself.
Maybe it's the intials / signature of the person who stamped out the tag itself? HAHAHA
86 LX Coupe 4E
85 SVO Hertz 4E
86 SVO 7B
66 Fastback
How many rocker panel parts were there? And what was the difference?
When lacking RA/LBP, what code was different (or missing)?
Urathane Lower Bodyside Protection supposedly became standard in '85, yet some '85 and '86 Buck Tags have the NLR code and some do not.
Is it a 100% sure LL is lift gate louver ?
Im kind of leaning towards KenP theory.When the bodies were assembled they didnt stay in that particular order all thru to final assembly.Im almost positive nothing on the bucktag is shift related.Why i was asking about LL being liftgate louver is because it seems to me that would be on the build sheet and not the bucktag.A build sheet was assigned to a car at our plant only after it left paint and im pretty sure its like that in all plants.At my plant they were always a big storage in body shop a storage going into paint and another after it left paint getting ready to head to trim and in trim is where the build sheets were added
where else could i look for this tag?
Stable:
Just for a comparison here is an SVO tag that I have saved as an example. I do not own this SVO. In the place where the "NLR" is normally located this tag reads "EI". Remember all SVOs came standard with the modified rocker molding to attach to the spats.
I figured I'd just confuse things a little more?
This is also an early build ( 10/83 ) slapper bar SVO.
86 LX Coupe 4E
85 SVO Hertz 4E
86 SVO 7B
66 Fastback
86 LX Coupe 4E
85 SVO Hertz 4E
86 SVO 7B
66 Fastback
I'll take "What is NLR on buck tags" for $1000 Alex...
HAHA
http://www.youtube.com/watch?v=vXGhvoekY44
86 LX Coupe 4E
85 SVO Hertz 4E
86 SVO 7B
66 Fastback
Wow it's about time somone responds to my post! And here i thought I was being ignored.
83 GT Turbo
This is a tag pulled from a junkyard car. 86 GT vert. No further information about the vehicle. Door sticker was gone. The car was a shell. No NLR on tag.
I forgot Buck Tags from all '86 5.0L Capris and Mustangs should have "EI" too. The '84/'85 5.0L CFI models should have "CI".
Looking through the '83 Turbo RS tags that I have, none of them have "EI".
82 Black Magic tag, no NLR
