My 84 is missing the cargo cover. Will any year fit?
...That.. that doesn't work for me. I gotta have more cowbell!...
No, the early ones changed the hooks in the back I believe. I think 84-86 should fit at least. Maybe 83-86.Originally Posted by Lizardking
-Mike
i concur, 83-86
Having no ASCII art is NOT cool
Whatever the rear hooks onto is also missing.
Its been so long since I owned a Fox, I just dont remember what everything looiks like.
They hook into the rear plastic panels in the back of the hatch....do you have these panels?Originally Posted by Lizardking
-Mike
The hook-ins at the hatch are different, and where it actually mounts to the interior plastics have different latch-in arrangements. 84-86 are the ones I have found interchangable so far.......
My 84 slides in from the top.
My 93 slides in from the back.
Won't interchange.
Albert Einstein
1984 20th Anniversary GT350
Almost "Stock"
The privacy shade/cargo cover breaks down as follows:
'80-early '84 (same length as late '84-'86)
late '84-'86 (same length as '80-early '84)
'87-'89 (shorter than '80-'86 due to redesigned trim)
'90-'93 (shorter than '87-'89 due to redesigned trim to accomodate rear shoulder betls)
'80-early '84 attaches to the underside of the liftgate
late '84-'93 attaches to the rear plastic that surrounds the liftgate striker
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
o.k., so it is 84, but the earlier ones would fit if the attachment point in the hatch was fixed
