Is there some trick to getting the '79 door panels off as opposed to the years with the lock in a more conventional place? I've dealt with the armrest screws, door pull bezel, mirror "triangle" thingee, and of course the panel clips. It's loose around the edges, but there's something holding tight in the upper middle that I can't quite figure out. Glass is up; I tried to lower it to see if that would help, but it's stuck in the raised position now.
Please help before I get out the sawzall...
