Results 1 to 6 of 6
    Default Aluminium bumpers vs steel bumpers - front and rear weight comparison
    Hi,
    Today I've pulled the aluminium bumpers off my parts car and compared them with the steel ones of my Ghia, and used a scale to compare the weights (probably not the most accurate but it does the job). Here are the results :
    Front steel (with turn signals and housings) - 15.5Kg 34.2lbs :
    Front aluminium (with turn signals and housings) - 6.5Kg 14.3lbs :
    Rear steel - 14.5Kg 32lbs :
    Rear aluminium - 6Kg 13.2lbs :
    That's a major difference, around 2/5th of the weight of the steel bumpers.
    Hope it helps
    Jan 2011
    Vancouver BC Canada
    That sounds about right, I measured 18 lbs difference between the steel and aluminum F bumper supports, I never bothered with the rear, since my 85 is a drag car, and the weights in the right place. Also, the only aluminum rear I had was badly corroded around the lower mounting holes.
    Just changed my front and rear over to Aluminum. Thinking about swiss cheesing the front.
    I built front and rears for my 88 out of chromoly. Probably half the weight of these aluminum ones. I'm going to build some for my 80 coupe with the turn signal brackets out of round bar. I may make a few extra sets and sell them while I'm already at it.
    Awesome info!
    What I like about this is what else can you take off the very tip of the nose of a fox and replace it with something around 20 lbs lighter that has ZERO impact on the appearance of the car?
    I like the moly setup too - very cool.
    I am certain some of you guys have the formula for the ideal drag fox and the ideal road course fox worked out down to spring and shock/strut info, etc.
    What I can see is a glass hood and some tweaks under the hood like battery relocation, AL radiator, and AL heads and you might get a car somewhere near a 50/50 weight balance. Heck glass fenders too for that matter. Somewhere near a 50/50 would be awesome for every use case I can think of. Shove the wheels forward and motor back or build a lighter power plant and more stout rearend if you want weight distribution biased to the rear.... and leave the steel bumper out back too.
    thanks for the posts- I've enjoyed the read.
    Oct 2014
    Calgary, Alberta, Canada
    No luck sourcing aluminum bumpers for me so I used a fiberglass front from an aero car modified to mount the signal lights and swiss cheesed the rear with a hole saw. The front is super light, the rear lost 8 pounds.
    Name:  2015-11-30 14-18-26 - 0003_resize.JPG
    Name:  2016-09-21 10.17.27_resize.jpg
