anyone have a whit or light colored 85-86 capri RS with the charcoal trim painted properly, it is hard to see on the dark colored cars, especially around the doors, im sure neg does...... but one in white so i can see it
Having no ASCII art is NOT cool
I'm not convinced that the window frames on the doors are the same grey color as the rest of the grey trim on the '85-'86s. Black possibly?
my door frames are actually gray, you can see the 2 colors inside the jambs, it is black on the bottom, then where the frame meets the door you can see the factory gray paint inside
