Anybody replaced one in an LTD (LX)? Same part as the Mustang/Capri?
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
DeanT had tossed a Fairmont radiator in a 84 Mustang. The Mustang tank on the passengers side of the radiator is different than the Fairmont/LTD (LX). You would need to change the rubber gasket/pad on that clamp that bolts to the radiator support for it to look right. DeanT removed the smaller rubber pad so the Fairmont radiator would fit. So, with that said... I'm sure it'll fit since an LTD LX is basically a Fairmont.
Edit: Ok, I have no idea why that picture isn't showing.
Radiator CORE SUPPORT, not radiator.Originally Posted by Marz
James Peterson used a Mustang core support to replace the stock one on his LTD LX that he bought wrecked. I don't see any reason why it wouldn't work.
85 Ford LTD LX: Four eyes and Four doors
EFI swap, AFR 165 heads, 5-speed conversion, Cobra brakes, etc.
