I just bought a powerdyne s/c and am having trouble understanding a few things.
I read that you can s/c a speed density car, but cant find anything relating to tuning it and what not. I looked on powerdyne's website and they claim you must convert to MAF. I would like to run the basic 6psi for now until I get use to it, is there anything special I need to do to a s/c on s/d? I keep hearing of a one way check valve, what does it do and where does it go? what would the recomended timing be if I run 6psi and n/a I have it at 14*?
Also about a boost gauge, where does this go "to get the reading"? in the inlet pipe(to the t/b)?
the engine is fresh (stock 87up specs with valve relifes) with 40K or so
e7's 87&up intake, 65mm t/b, gears exhaust and a 255lph intank
pump(I use to spray it)
any and all info you feel I should read before bolting it up, please let me know.
Thanks alot
