Hi all,
I need to replace the MC in my 78 Zephyr (see my sig for my complete setup) as it is getting rusty and may be leaking a bit. My current setup is an early/mid 80's Fox type cast iron MC (I think this MC has a 15/16" bore) and matching booster, with 87+ Mustang 11" rotors/spindles and 60mm calipers.
I am thinking of replacing this MC with the aluminum 85 Town Car MC with 1" bore. I believe this swap should be 100% plug-and-play (as far as brake line fitting sizes and locations). Im thinking of using this MC primarily as it will not rust and is lighter.
My question is it a bad idea to go with the 1" bore MC and the existing 60mm calipers? I've read different opinions here regarding the 73mm calipers and their worthiness. My Zephyr is 100% street driven and not driven all that hard. But I still want to be safe and be able to depend on my brakes in an emergency.
Also can anyone give me details (or a link) on the booster rod adjustment procedure? Is this a bit of trial and error?
All opinions/info welcome.
Thanks,
Paul
