Results 1 to 25 of 30
    FEP Power Member slickshift's Avatar
    Sep 2004
    Cape Cod, Massachusetts
    Default Caster Camber plate recommendations
    Well, one of the old plates is busted
    That's why my "Fox Lean" was in the wrong direction
    They were crappy anyway, very hard to adjust caster w/o messing up the camber and vice-versa
    Any suggestions as to a good set for the twisties?
    Something kinda user-friendly?
    '86 GT that technically doesn't exist
    With Accessory Reserve Load Springs
    Accessory Reserve Load Springs...Whooo Hooo!
    My Maximum Motorsports ones are great. I like the lifetime warranty too.
    Yup... MM C&C plates all the way.
    FEP Power Member Mumfts85gt's Avatar
    May 2004
    Wichita, KS
    I'm lovin' my MMs too.
    Rob.
    1985 GT 4V H.O. Work in progress, off and on, since December '87. http://www.cardomain.com/memberpage/606903/1
    FEP Power Member Tar 71's Avatar
    Mar 2004
    Southern IL
    Another one for the MM c/c plates, they are great. Tim
    86 GT 363 w/80mm turbo-currently under construction
    19 F-150 Lariat Supercrew-DD
    Jul 2003
    Casa Grande, AZ.
    same as above
    down to two eyes
    seller of the FIRST 4-eye in Modified Mustangs Magazine!
    note to self: get MM CC plates.
    Sep 2004
    Wow, looks like MM CC plates take an early lead over...nobody else so far
    I'll have to check those out
    FEP Senior Member underdogGT's Avatar
    Oct 2002
    Jacksonville, FL
    ok i will chime in.....
    I have the Steeda plates with the billet top plate
    Lifetime warranty too
    1983 GT(to many mods to list)
    http://www.cardomain.com/memberpage/607351
    FEP Power Member Cappn Tripps's Avatar
    Jul 2002
    chandler, Az
    have QA1 plates here, no probs and I wanted steel plates...
    my car is slow....
    84 GT convertible
    13.58@102.84, 2.01 60ft... summer in AZ...
    68 coupe.. lookin for 8's with a street car
    http://members.cox.net/darkknight302/68nwrear.jpg
    MM plates on both my Mustangs.
    86 GT vert - all motor 306 drag/street car - 11.88 @ 116
    89 LX 5.0 - slow daily driver
    FEP User
    Aug 2004
    Hattiesburg,Mississippi
    MM here!
    Apr 2003
    Oklahoma City, OK
    HPM's here I like em
    1973 Mustang Sportroof 5.8C
    1974 IH 1010 6.4L
    1983 Crimson Cat 5.0L
    1985 LTD LX 5.0L
    1986 SVO 2.3T
    1989 Mustang Coupe 5.0L
    I have used and installed MM, MPH and Ford CC kits. They all are nice. I would just recommend staying away from the ones with rubber or poly bushings. I like the styles where they uses steel spacers.
    Mike 1986 Mercury Capri original paint, t-top car
    331ci, AFR 185's, Vic Sr. SFI intake, Custom 80mm t6 frame turbo kit, AOD, 9" w/ 3.25 gear and drag radials.
    Fully loaded street car with cold a/c
    9.31 @ 146 1.37 60' Just getting started! 88mm turbo going on in 2010
    Jun 2003
    Northern Colorado
    Ok here's a question for everyone.
    Why doese Ford/Steeda list 79-89 plate's AND 90-93 plate's when everyone else list's one part# for 79-93?
    I used the Ground pounder plate's and thought they where the biggest piece's of purple poo I have ever seen.
    My next purchase will either bee MM or FRP.
    kyle
    1986 Thunderbird 5.0/AOD
    What I noticed is there was a difference in the hole opening for the strut between the two year styles. One had it offset to the front and the other to the rear. FRP and others just made on large opening to cover both styles. The FRP CC plates I just installed on my car still had the instructions for the two styles. lol
    New User
    Jul 2003
    Baltimore, Ontario, Canada
    I use hotchkis and love em
    86 Capri
    DSS Bullett Stroked 410
    C4 with 4200 stall
    Custom Comp cam
    Edelbrock Victor Jr.
    850 Mighty Demon
    BBK Full Length
    MSD ignition
    PA Racing K-member
    Plus much more.........
    AND a very understanding wife!!!
    FEP Supporter PROSTOCKTOM's Avatar
    Jan 2016
    Terre Haute, Indiana
    Maximum Motorsports on my Fairmont
    Tom
    May 2005
    Altoona, PA
    This has to set some kind of record for back from the dead. Going on 11 years!
    408/T5/3.73's
    Jan 2011
    China Grove, North Carolina
    Threadsurrection!
    FEP Power Member blackgt85's Avatar
    Dec 2005
    Sussex, WI
    Hell, I'll add to the Maximum Motorsports recommendations! They are my choice for most anything suspension related!
    Justin
    May 2005
    Altoona, PA
    I've been happy with everything I ever bought from Maximum Motorsports. Their stuff isn't cheap, but you get what you pay for.
    408/T5/3.73's
    FEP Super Member escogt's Avatar
    Jan 2006
    Long Island, N.Y.
    Yep. MM here too. Good quality parts!!
    '85GT Bright Atlantic Blue
    '92LX Bimini Blue-sold
    '93 COBRA Teal Metallic-sold
    '86SVO Oxford White-sold
    '86GT 'Vert True Blue-sold
    '81'GT' Medium Red-sold
    FEP Power Member Mikestang's Avatar
    Aug 2013
    Firestone, CO
    MM, only way to go for quality!
    1986 Ford Mustang GT-
    Not much stock stuff left
    347 NA power, CNC ported heads, Extrude honed Trick Flow Intake, Custom Cam
    Suspension, custom k- member, TQ arm/pan hard rod... Much more
    Restored and ready to race, made to go fast while cornering
    1981 Mustang GT-
    Old SCCA A-Sedan National Champ car
    In the middle of rebuild
    1986 LX Sedan-
    Plans to be determined...
    "Every day I learn how much I don't know"
