Results 1 to 24 of 24
    Default Converting to manual crank windows a bad idea?
    I have a an '84 with power windows and today I saw an '84 with manual windows. Would be a good idea to dump the weight of power windows and convert to manual crank or is that a stupid idea - especially since I have 37 lbs extra weight from the sun roof?
    Thanks,
    Dean T
    Why would it be dumb.
    Only thing I see missing would be the cool factor of the window going down. Cause looking cool while cranking the crank is near impossible.
    If they work I'd leave them. Manual windows only save a pound or two. Not as much as people think.
    Black 1985 GT; 408w, in the 6's in the 1/8 mile
    FEP Super Member anthonydalrymple's Avatar
    Nov 2004
    Salt Lake City, Utah
    Quote Originally Posted by Zap's 85 GT
    Not only that, but you'd have to either get manual door panels or plug & cut on the existing panels, right? Not worth the effort in my opinion....
    '89 5.0 5-speed 'vert, seeing rust for the 1st time in it's life as well as 4,500+ elevation....
    Travis T
    Guest
    No, the hole is in the same place for the switches and the handles, but the driver's side would have a big hole around the handle if you did the conversion. It would be more headache than it's worth.
    FEP Power Member moelll's Avatar
    Jan 2003
    Placentia, Ca
    and you have to admit, it'll be alot less of a pain having crank windows cos you dont have to worry about fried motors and broken switches.
    and its not about the weight, iin my opnion, the power window motors only put more strain on an already strained alternator (if you still have the stock)
    and its just simpler keeping crank wiindows
    1985 Ford LTD LX. 4 eyes, 4 doors-cobra powered
    2006 Ford F-150 Ashley/Smith special edition--the "daily driver"
    1986 ford mustang SVO--a man can always dream right?
    Thanks for the feed back. Yes, I would have to change the door panels too since the cranks are located in virgin territory on my door panels and my window switches are mounted directly below the arms rests - makes them hard to see when you're sitting in the seat!
    I guess I'll stick to the power windows since I need to get the car back on the road!
    Regards,
    Dean T
    Quote Originally Posted by Dean_T
    Dean T
    Dean... I dunno about 84's man... but on my 85 the switch thats under the door armrest is for the power locks. Maybe your 84 was miss-wired? I dunno....
    Jun 2002
    Indianapolis, IN
    I prefer manual cranking windows...les stuff to go wrong later.
    Thats just me, I prefer to keep it simple.
    85 Mustang Coupe, 3.3L I6, C4, 8.8 3L23, 17x8 wheels. About 70% towards firing it up.
    Quote Originally Posted by Marz
    Dean T
    Yup, both my 85 and 86 are that way...but...could just be the way they did it depending on the option since both of my cars have power locks, but have manual windows. Now if he has power everything, thats different, but could have manual locks and power windows...not a clue...got answers?
    I'm not aware of any four eyed mustang with power window switches under the arm rests. I see a lot of mustangs and capri's when I go the junk yards and I have NEVER seen one with power window switches under the arm rest.
    Corey
    1965 Mustang
    1986 Mustang GT T-Tops - Explorer engine swap, MAF Conversion, 5 lug Cobra Brakes
    2001 True Blue Bullitt
    www.thompsontransmission.com - coming soon
    Fox Body Black Interior Interchangeability Guide
    Quote Originally Posted by moelll
    Sorry but this simply is not true. Theres nothing simple about crank windows. Have you ever tried installing a manual window crank? <raises hand> I have, lol. I have previously owned 2 different cars that have required a manual window crank replacement. This is NOT FUN TO DO. I hate crank windows with a passion. The manual cranks always go out, they are irritating to replace, irritating to have to reach over to roll the passenger window down. Crank windows work fine and then eventually the crank starts getting really difficult to roll the window up and down and next thing you know it, your using 2 hands to try and roll the window up...and then the stupid handle breaks. Ask me how I know. The second car I bought had a bad window crank on the driver side the day I bought it. About 2 years later the passenger side window crank went out and I said screw it, that window is now permanently going to stay up.
    The power window system in our Mustangs is so simple it's not even funny. 3 or 4 bolts and the window motor out, disconnect the harness, plug in the new one, bolt it up, get someone to hold the window so it doesn't crash into the door. As long as you have a good alternator, I wouldn't worry about putting a strain on anything.
    Corey
    1965 Mustang
    1984 what? Fairmont, Zephyr, Capri, Mustang?
    The Capris and Mustangs only had the power locks under the arm rests....power windows or crank windows used the same spot...higher and forward of the arm rest.
    -Mike
    dean is talking about my brothers 84 Notch that he bought.
    Corey
    1965 Mustang
    V6DR
    Guest
    yeah manual cranks windows rule
    Quote Originally Posted by negusm
    -Mike
    Yeah and I think there is a cut out thingie there for removal for the switches.
    Quote Originally Posted by mfpmax
    -Mike
    Yes. The cardboard is perforated under the armrests for adding power lock switches and at the crank for power window switches.
    On the driver's side, you CANNOT mismatch them without working at it!
    On the passenger side, I suppose you could switch them as the switches are the same size but I don't know if the harness would allow it.
    -Mike
    Yeah cause the driver side has two switches while the passenger has one.
    My bad, I got the window and lock switches mixed up. The window switch is forward of the arm rests. I have been working on the HVAC so have been working out of the passenger side a lot. I'd still have to replace the driver side door panel if I'd convert to manual crank windows since the power window switch is huge.
    Oh man, I remember a time when the power windows used to crap out before the manual window versions. Now days, it looks like the opposite is true.
    Anyway, I'm going to a bit busy getting the HVAC and the underhood vacuum lines corrected to mess around with the power windows.
    Oh, yes. '84 Mustang. Fairmont/Zephyr production ended in '83 and I don't think the LTD, Thunderbird, or Cougar ever had manual crank windows. Does it really matter what car model I was talking about? I was comparing manual versus power windows in the same model of car!
    Regards,
    Dean T
    Travis T
    Guest
    I've never had a problem with Fox manual windows, and I've owned many of them.
    Probably not...I just don't know exactly what Ford did in anything other than Mustangs or Capris....and I saw a "Futura" tag in your sig...
    FEP Power Member LTDScott's Avatar
    Oct 2004
    San Diego, CA
    [quote="Dean_T"] I don't think the LTD, Thunderbird, or Cougar ever had manual crank windows./quote]
    FYI
    85 Ford LTD LX: Four eyes and Four doors
    EFI swap, AFR 165 heads, 5-speed conversion, Cobra brakes, etc.
    Quote Originally Posted by 50 Proof
    my 85 has the power lock switch under the arm rests
    Quote Originally Posted by 85saleencoupe
    yes, as it should. however your power window controls are in the same place that the manual window crank handle would be
    Corey
    1965 Mustang
