Theres a pull knob on the bottom of the dash to the right on the steering column, looks factory and says amp pull on it. Wth is that?
The "Premium Sound" system has an amplifier that is located in the center of the dash, beaneath the dash pad. Pulling that knob out turns the amp on. Pushing that knob in turns the amp off.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
ahh, i see. Thanks for the response. I was thinking of amp in an electrical type of way. i never woulda thought of a stereo amp. Thanks
Can this be used to power a,larger aftermarket amp? Does anyone know exactly how much juice this provides? Thanks
Sure if you use it to power a relay
I would think of it more as the remote power to turn it on. You'll need a designated power wire from the battery for a large amp.Can this be used to power a,larger aftermarket amp? Does anyone know exactly how much juice this provides? Thanks
83 Mustang GT , A5 5 speed, 31 spline Cobra rear, LMR TRX, 302 11r 190 heads, Buddy Rawls custom cam
86 Capri , 342 stroker , AFR 185 heads, Track Heat intake, 3.73 gears
It's basically a power booster for the rear speakers only. Not sure exactly how it works, but I'm "assuming" it works just like an old 80's style graphic EQ/power booster that is wired inline from the stereo. So AMP PULL turned off you are getting the low wattage from the stereo, and AMP PULL on you are getting the additional power from the amp. I'd love to know the specs of the radios power output and that of the amp when added. I'm guessing it is rather low...as in probably in the teens
Jason Smith
MCA #65481
'82 Capri RS Resto-Mod
'05 S-281 Mineral Grey
-David
The Brown Blob
Anyone know how to remove the knob so that it can be reused? I don't want to break it.
-1983 Mustang GL Coupe 9D Polar White (Sold)
-1992 Mustang LX 5.0 PM Bright Calypso Green
-2019 Jetta SEL (DD)
-1982 Oldsmobile Cutlass Brougham (Wife's Toy)
-2012 Nissan Xterra
88 Turbo Coupe auto
88 Turbo Coupe 5spd
79 Fairmont Futura 4.6
80 Capri 5.0/5spd project
79 Pace Car 5.0/5spd project
86 GT conv 5.0/5spd
Thanks for the help. After trying every allen wrench I have, I carefully twisted the assembly to look at what size wrench I need I discovered it's simpler than that. Apparently in '83 the knob is held in place by a friction spring metal piece. Compressing the clip releases the 'bite' on the switch shaft.
Maybe this will help someone else in the future.
-2012 Nissan Xterra
I use the one in my car to turn on the line lock.
Cale
