Results 1 to 11 of 11
    Default K-member questions
    I need to know which k-members work for which engines.
    Do the 5.0, 4.2, 3.8 all use the same k-member?
    The straight 6 and 2.3 the same k-member?
    Thanks!
    Mar 2004
    Spring Hill Florida
    302 and 2.3 are the same. not sure about others but I know V6 member won't work for 302 swap.
    Thanks!
    Any more info out there?
    2002 F-350 4x4 PSD
    2000 Excursion 4x4 V-10
    1990 Mustang LX 5.0
    1984 SVO
    1982 Capri I-6
    Straight 6 is the only different one.
    That sucks! That is what is in my capri that I am planning to pull out.
    I guess the others simply use different motor mounts?
    2002 F-350 4x4 PSD
    1990 Mustang LX 5.0
    1984 SVO
    1982 Capri I-6
    I believe so.
    Is there a reference somewhere that I can look this up or confirm this before I purchase a k-member for my capri?
    2002 F-350 4x4 PSD
    1990 Mustang LX 5.0
    1984 SVO
    1982 Capri I-6
    jazzcat2001
    Guest
    get a tubular one
    if you dont want to go that route you can have mine(from an 86 coupe 2.3) after my fiance gets her car
    That would be sweet. The only problem is that i am in TX. It might cost more to ship it than I could buy one for. If you have any ideas on how i could get it I would definitely use it on my capri.
    2002 F-350 4x4 PSD
    1990 Mustang LX 5.0
    1984 SVO
    1982 Capri I-6
    tanker checo with ups and fed ex ground, and see what they want for shipping, as i recall the K member only weighs like 90 lbs(dont remember though), and as i recall it should only run something like $75 for shipping from mo. to tx. again it has been awhile.
    64 falcon
    66 mustang
    05 grand marquis
    dont just believe in miracles, rely on them!
    fordsix.com admin
    FEP Power Member Zephyr 351C's Avatar
    Sep 2002
    Western NC/East TN
    Quote Originally Posted by TANKER
    Yeah, right here.
    -Zach
    '81 Zephyr Sedan: In pieces. Some at the garage, some under my bed, etc...
