how did you do it? i want to do sn-95 up fron (98 gt brakes) aerostar axles out back and stock 03 cobra wheels? any advice suggestions things im going to need to get? etc etc etc.......
Blake
Blake
1973 Mustang Sportroof 5.8C
1974 IH 1010 6.4L
1983 Crimson Cat 5.0L
1985 LTD LX 5.0L
1986 SVO 2.3T
1989 Mustang Coupe 5.0L
I'd suggest you check out http://www.svo73mm.cjb.net./ . It has a comprehensive list of your options.
great info on that site.
My 83 with the Ford Racing Cobra 2300k kit work fine
Be careful using 9 inch wide wheels up front with the 96-04 spindles. That few extra millimeters on each side can cause frustration with clearance. Just read up on Matt's site that was linked above. There is more information there on what to do than on any message board. AND it is accurate.
Well the 2300K Ford Racing Cobra Brake kit uses 94-95 spindles. The only issue to come to mind was I needed steering rack limiters.
