I have a 1986 gt that has the following mods.
gt40 upper and lower
f-cam
off road x-pipe
flows
msd ignition
mass air conversion
cold air intake
The problem that i am having is it is running extremely rich and gettin about 120-140 miles per tank of gas, and most of the time the idle will fluctuate up and down. In wide open throttle is is great, but i can not figure out what the problem is. I have put a new coil on, a new iac valve, checked the wires and plugs. The only thing that i can think of is maybe the o2 sensors are bad, or maybe the egr is bad. I resest the tps to the specs that it is supposed to be (.98-.99) and that helped the idle a LITTLE but i cant afford the gas that i am having to put in it all the time. Do you think that it could be the egr or the o2 sensors, or could it be something else? Really need to get this solved. I was told by one person to put an adjustable fuel reg on it but i was told by someone else that it would not solve anything. I have the stock injectors as well. Thanks in advance.
Cody
