ok first a little background info. i took the old engine out and the car sat for a few weeks. my dad hooked up a small wire from the negative post of the battery to a ground so that the alarm will still work. after putting the new engine in, i had the key in the on position and the check oil light came on. after i finally got around to putting oil in it, the light went away right afterwards. the thing that i dont get is that the actual gauges dont seem to be working. when i turn the key to the on position, the fuel level gauge rises like it usually does, but it stops at its lowest postion and the low fuel light in the little cluster under the radio stays on. i had the lines that connect to the mechanical fuel pump to the tank uncapped for those weeks, but could it be possible that an entire tank of gas evaporated through just those lines in that time? im thinking that the gauges themselves arent working since when i tried to crank the engine the voltage gauge didnt dip down like it normally does. after searching, im wondering if its the internal voltage regulator for the gauges, but why would it all of a sudden not work? ive tried looking through wiring diagrams to see if i missed anything that i missed under the hood. i left some manifold sensors off that normally control emissions equipment like the thermactor valve, etc, but are those necessary to get the gauges to work or can the IVR just stop working all of a sudden?
sorry for such a long post, but i figured too much info is better than being too vague. has anyone had a similar problem or is there some thign under the hood that i need to hook up?
TIA,
