Anyone running a Crane Hi6?? Does it work with stock tach. Right now I'm running an Autometer with it, but I wouldn't mind going back to the stock look. I couldn't get the tach to work with it. Do I need an adapter??
My factory tach works just fine with my HI-6 w/o an adapter. I have a wiring harness and dash from a '93 (for EFI conversion) though, so I don't know if the earlier cars hook up the same.
-Mike
'83 Mustang GLX---T-Tops, 5.0 EFI/TKO600/8.8, Ebrock hds/int, F303, 4whl discs, 3.27s, 70mm turbo @16psi.
If you have a tach from a '93 model year, then chances are that it has different filters in it from those from '79. Actually my tach is from an '86 GT but I think it's the same as my orginal '79 tach.
