well here you go guys with pics and all!!!!
if you dont know how to remove your headlight switch simply reach under the dash and on the headlight switch there will be a little knob on the bottor of the switch simply push that up and the pull the headlight switch like u were goin to turn the headlights on and the staff will pull right out, then loosen the plastic trim nut and then the switch will be free
ok well if u look up under your dash right near the headlight and foglight switch you will see a relay that looks like this
this is the relay for the marchals now what u want to do is find the red and black wire that comes out of the cluster of wires and goes into the plug that is going to the back of the fog light switch
like this
there will be a blue wire and the red wire u want to cut coming out of this plug
then take the red wire that u cut (making it longer if u need to as u will need a little bit of slack to tuck the headlight switch back up under the dash)
and plug the red wire in with the BLUE AND RED wire going into the headlight switch connecter liek this
then when u turn the parking lights on the foglight switch will be working and you can drive with the parking lights on and the fogs or just the parking lights.
