Can someone send me the correct wiring for the alternator on the 84?
It has 2 plugs that are screwed on the back and one that is just capped on...
I think it took a dump, but want to make sure... I can describe better later, but I believe it to be the same setup for the 84's... since the newer ones have different clips....
Also, if I go one wire alt., just tape up and hide the current wires?
