Can't decided which ones to get. The Eibach springs im looking at lowers the front by 1.7", rear 1.5". The FRPP C springs is front 1 1/8", rear 1". I will likely stick in a 351W block. Should i run the C springs so it doesn't lower the car that much, with the weight of the engine? I wonder whats the weight difference between the 302 & 351W. What struts are you guys running with lowering springs? I already have red koni's for the rear. THANKS
