Hello:
I'm trying to find out when Ford starting making 5 lug available on Mustangs. if it was in the 1984 - 1986 time frame does anyone know if the pattern is the same as the 2001 model year.
Thanks!
Carl
Hello:
Thanks!
Carl
The 5 lug mustangs didn't come into effect until the new body style in 94. Maybe the 93 cobra's had 5 lug, not sure on that.
If you're looking to go 5 lug on your 80's mustang, then it is common to use the 94+ stuff on the fox body's
Jeremy
'84-'86 SVO is 5-lug. And yes, the bolt pattern is the same as '93 Cobra R/SN-95.
'93 Cobra is 4-lug.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
Transmission Tag Decoder
VIN Decoder
I'll be damned!!! Never worked on an svo before,hell, or even looked at the wheels up close. Good stuff to know.Originally Posted by FoxChassis
Jeremy
Thanks for the info, guys. I'm just curious as I'm starting my search for a 84-86 GT.
I'll wait to hear back from you (v8only) after May 8 regarding your car for sale and our discussion.
Thanks!
The 93 Cobra R was 5-lugOriginally Posted by FoxChassis
-Zach
'81 Zephyr Sedan: In pieces. Some at the garage, some under my bed, etc...
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
doh.. Where you been man!!!l lol. Svo 5 lug 4 wheels disc koni's tubular control arms all sorts of neet cool stuff...Originally Posted by v8only
kyle
1986 Thunderbird 5.0/AOD
REALLY!!! I've never found a complete one in the junkyard (ok once, but I didn't know what to take), never knew anyone who owned one, or even worked on one!!!! I'm at a complete loss here.
Koni's??? Tubular control arms??? i didn't know this. I'm going to have to get a better look next time I run across one at the yards. Ford should have put all of these neat parts onto the v8 gt's. now i see why the svo's are so popular.
Jeremy
The front arms were tubular. But forget about putting them on any other Mustang. You'd need sleeves for the ball joint that CCM used to make but doesn't any more.
Axle Tag Decoder
Buck Tag Decoder
Door Tag Decoder
Owner Card Decoder
VIN Decoder
Griggs still makes the sleeves to run svo spindles on regular lower control arms. The svo control arms are IMPOSSIBLE to find. But my brother and i have a nos left side.Originally Posted by FoxChassis
kyle
The front brake setups of the 84-86 SVo and the 93 Cobra R/94+ Mustang is completely different. ALL 5-lug stang rims will fit the SN95 style, but not all SN95 rims will fit the SVO rotors
-'88 Mustang LX 5.0L
Very true.. The dust cap hub area is bigger on the svo rotor/spindle. But wheels built before 96 will fit. Otherwise you need to machine the wheel or the rotor..Originally Posted by Mustang5L5
kyle
Then is the rear with discs the same width as the mustang or is the same as a Turbo T-Bird.
86 Capri 5.0
86 F150 stepside
85 crewcab stepside project
66 VW Bug
73 Dune Buggy
The SVO rear is actually wider than the T-bird. It's 1.25" wider each side than a standard drum brake Mustang.
But the rear setup can be modified to retain stock axle width. I myself run SVO rear brakes modified to use ranger 5-lug axles. Here's the write up
http://home.pacbell.net/black306/tech/reardisc.html
I used to have the SVO fronts as well, but i went with cobra 13"
