If I use the Lincoln spindles then I need to get a sleeve for the balljoint correct and I can use the stock strut for the 86. If I do the sn95 spindles and rotors then what struts would I use. Thanks
86 Capri 5.0
86 F150 stepside
85 crewcab stepside project
66 VW Bug
73 Dune Buggy
if you use the lincoln set up, yes you will need to get a sleeve, but you will also need to use a 87-93 strut. if you use the sn95 spindles, you will need to get the sn95 balljoint pressed into your front control arms or you can use a balljoint spacer(or stack of 3 washers) totaling .330" in heght, and use the same 79-93 front struts. also, check out http://svo73mm.cjb.net/ this site will tell you everything you need to know
