wiring help
hey guys i need some help wiring up a duraspark ingnition. i am doing my cfi to carb converstion and i need to know how to hook up the new coil and duraspark box.i know that the dizzy will plug right into the box, but how do i wire up the coil and the hot wires and to the duraspark box.... somebody please help an ole boy out
the coil will probably stay the same. on you TFI plug there will be a wire that is Hot with ignition, and another hot with key in Start position. these hook up to the red and the white for the duraspark box. I'm not sure which one is which though. Consult you haynes manual for that
- You may not post replies
- You may not edit your posts
Forum Rules
