Results 1 to 6 of 6
Thread: Rough 86
    Default Rough 86
    I just picked up an 86 GT. The guy told me it overheated, blew a head gasket and was gushing antifreeze. It has not been on the road since 2005. I got it fired up and topped off the radiator. It was half full.
    I ran it for almost an hour without the radiator cap. It smoked a bit until it warmed up but t cleared up. No signs of any water leaks. Oil looks fine. Radiator was replaced some time ago. I guess I should pull the plugs and check them. I will have to try the cooling system under pressure.
    Any suggestions?
    Car has 130k miles and mostly original right down the factory exhaust.
    qikgts's Avatar
    I agree. Put some pressure on it and see what happens.
    You can also try out a combustion gas tester.
    https://www.summitracing.com/parts/lil-75500
    Mar 2003
    Lowell, Oregon
    I assume the head gaskets were replaced?
    Agree with pressure testing cooling system and check plugs.
    If those items are ok, run it with the cap in place for awhile.
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    1993 Volvo 240 Wagon
    Found a gasket set and new oil pan in the trunk. Maybe next week I will check it out some more.
    Sounds like a fun project. Be sure to post some pictures when you get a chance!
