Results 1 to 10 of 10
    Default What are people using for AOD TV cables?
    So, I never figured that an AOD TV cable for a 5.0/AOD Fox car would be unobtanium from Ford. What aftermarket cables are people using on the 86-93 5.0 AOD cars? I'm going to need something for the LTS.
    Thanks!
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Jan 2003
    Muskegon (Power Tour stop!)MI
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Those are shift cables. I need the TV cable. The CFI uses a rod, and I'm going to be converting to port-injection.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Chuck, have a look at a company called Lokar. they make a TV Cable for an AOD.
    Grand Rapids, MI
    There is an '87 Cougar 5.0/AOD at the junkyard near me. I can try to grab the TV cable for you if you'd like. I have to believe it is the same between the HO and lo-po 5.0 engines.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    That would be cool if you could. Hit me up in PM if you can. Thanks!
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    I used Lokar on mine
    Jan 2004
    Olathe, Kansas
    Are floor and column shift the same cable ???
    Now stang-less.
    88 Cougar 5.0
    The car had a floor shift.
    Kevin grabbed the shifter and the TV cable for me. Each is going to a separate project.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Grand Rapids, MI
    The '83 Cougar I grabbed some parts from a year or so ago with a column shift had a rod linkage from the column down to the transmission. Obviously the floor shift in the '87 I got the parts for Chuck from has a cable. I did leave the shift cable in the car since he didn't need it. If you need it let me know as I think the car is still at the junkyard.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '97 Thunderbird
    '85 Ford LTD Squire
