I have an issue with the 302 in my 83 Capri. It will misfire and spit back through the carburetor when i blip the throttle. It will start and idle fairly smooth and I can very slowly bring the RPMs up to about 3500 without issue, but hitting the gas rapidly causes the backfire through the carb. This engine ran very well when I pulled it from another car. I put it in my car where it has sat for over 10 years and I am just now getting around to messing with it again.
Initial timing is at 16 degrees with approx. 38 total
New plugs, cap, rotor, and wires
New ICM
carburetor was rebuilt (idles better than it did before but didn't help the spitting through the carb)
tried another carburetor with same results
Vacuum is steady around 13"'
Since the vacuum is steady and I can slowly rev it up, I'm thinking that there aren't any serious mechanical issues. I've tried two carburetors and they both have the same symptoms. Should I be looking into an electrical issue? If so, where do I begin? I have 12 volts to the coil. Am I supposed to have power to the distributor?
