    whs
    Guest
    Default Input on Exprience With Polyurethane Bushings
    Everything I have read says that the rear upper control arms should use the heavy duty rubber bushings. I am considering going with the ones from Steeda, they have the stiffer rubber bushings on the body side, and polyurethane ones for the rear end. However I would like to replace the other bushings front and rear all at once.
    I am seeking input on your experiences with polyurethane bushings either from energy suspension or prothane. I have heard some negative feedback on the prothane bushings, which is why I am asking for input here.
    Thank you.
    My experience wih poly is that if you put them in all locations, your car will ride very rough and also be very dangerous in corners. Poly in all locations causes excessive bind. Leave the top ones stock.
    1979 Mercury Capri RS 5.0
    cool86
    Guest
    go with the Ford uppers with upgraded rubber bushings and then you can use some lowers with poly- just went with the Steeda kit ( ford uppers and steeda boxed lowers) and the back end is extremely tight - car rides like new. the only downside is a bit more road noise with new LCAs
    as others have said, poly at both ends will cause binding and eventually screw up your torque boxes. This is mostly a problem on street cars, that will see cornering and handling too, so if you are building a strip-only car, poly away.
    I also agree with the cobra/frpp uppers (same thing, but the cobra units are cheaper) For the lowers I went with pro3i (very, very similar to max motorsports) it had poly at the body end, and a spherical metal like bushing at the axle end. Really good setup. I have a vert, so I can't tell if it's noiser or not.
    Jeremy
    Mar 2003
    Lowell, Oregon
    Default poly
    I am using the Steeda uppers (Stiffer rubber on both ends) with Mac Lowers (poly) and have been very happy with them. A little noisier but much better handling. When I had my subframe connectors welded I also had the shop add more welds to the torque box seams and all seems well. That was 5 years ago.
