Have an 86 GT w/5.0 HO engine. All original except for upgraded stereo.
Factory battery was a BX63.
Does anyone know what the CCA & CA’s are for this car, and which new Motorcraft battery in todays world would be?
Pretty sure this is the latest.
https://www.tascaparts.com/oem-parts...battery-bxt56a
That same battery may also be available locally....
https://www.oreillyauto.com/detail/c...6-ford-mustang
