I opened another thread about shoe size and that I had found 2 slightly different rear shoe sizes listed on multiple websites.
I determined that the 9 x 1.71 was the correct one and replaced my rear drum brakes earlier in the week. They can be tricky so I took my time and bought new spring kits etc. After I got both sides assembled and adjusted I put the tires on and since I had the car on stands I checked the rear brake function and was surprised to find that while engaging the brake pedal both tires continued to spin, even with the pedal pushed as hard as it could get it the tires still spun.
I tightened up on the adjustment some more but honestly if I tightened any more I would have cracked the shoes. I took the car to my mechanic and had him go over the whole set up. The only thing we found wrong visually was the self adjuster cable hook fell out on the driver side. Regardless of that, it would have affected self adjustment, not braking function. So I bought new self adjuster kit fpr the driver side only since the passenger side was assembled OK.
The wheel cylinders appeared to be functioning when stepping on the brake pedal and there was no fluid leaks in either side. We determined there to be poor pressure to the rear so we replaced the master cylinder. Now he had trouble bleeding the rear passenger side. They spent a better part of the day and it kept producing air. We tried putting the disconnected brake line into a large cup of brake fluid and pumped the brakes until bubbles stopped coming up and there was definitely a bled line. Reconnected the line, tried to bleed out the minute amount expected from reconnecting to the wheel cylinder and now the line is filled with air again.
He tells me he suspects the wheel cylinder is sucking air so I say if I'm changing one, I'm changing both. So off with everything and now a pair of brand new wheel cylinders. This time the system blead easy and the pedal is firm and high as it should. Drove the car and has great stopping power. The only thing, the rear tires still spin when the brake is engaged. This cant be normal. The car has great stopping power and doesn't feel as though I'm only using front brakes. I know that feeling when only the fronts are braking. Yet, why is it that engaging the brake while the car is off the ground results in the rear tires slowing but not stopping?
My mechanic suggested I look for a proportioning valve. Has anyone here had this issue or seen of it? Any links to the correct proportioning valve or even an upgrade that allows adjustment of pressure between front and rear?
Also, this whole mess allowed us to find the rear driver side axel seal was leaking oil so I also ended up pulling the diff cover, replacing the driver side seal and dropping 2 fresh quarts of gear oil and a bottle of friction modifier. I just rebuilt the 8.8 rear about 5 or 6 years ago. I'm surprised one of the seal leaked so soon considering the car isn't driven much.
