Results 1 to 7 of 7
    Jan 2003
    Muskegon (Power Tour stop!)MI
    Default Turbo Coupe rpm's
    Have a 86 Turbo coupe with the auto tranny and was wondering what highway speed rpm's should be. Is 3500 rpm's normal at around 70 mph?
    Is this safe for the motor? Seems like the engine is screaming at that speed.
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Jan 2004
    Olathe, Kansas
    That seems high to me, but its been awhile since i had my Turbo GT. Spin the tire one revolution and count the number of driveshaft turns. Will tell you what rear gearing is.
    Now stang-less.
    88 Cougar 5.0
    Jan 2003
    Wondering if there is a tag on the diff cover, will have to check? Would these have the smaller 7.5" rear end?
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    Apr 2010
    Portland, Oregon
    Not going into overdrive?
    Jan 2003
    From what I thought was it has 3 speed transmission, C3?
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    I think the 86 Turbo Coupes came with 3.45 rear gears.
    Grand Rapids, MI
    Sounds about right for a three speed trans. I guesstimated your tire size and came up with 3259 at 70mph with a 3.45 rear gear ratio.
    http://www.csgnetwork.com/multirpmcalc.html
    Yes, you should have the 7.5" rear if it is original.
    My V6 screams at today's highway speeds with the three speed and even 2.73 gears. I hate it.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
