So, my speedo gear on the output shaft either slid out of the way, or is missing. I'm not sure which. Regardless, I need to take the tailshaft housing off the trans if I want to have a working speedometer. Do you think that's something I could do without removing the transmission itself from the car? I'd really like to save time any way I can, and removing and installing this transmission on my back has been a real pain because I have my engine moved back on the K-member. It makes it damn near impossible to line up because the engine doesn't lean back as far as far as it normally would before it contacts the firewall. Not to mention I'm usually doing it by myself. And yes, in hindsight, if I'd known I would need to pull my transmission back out 5,000 times, I may not have made that decision.
