Results 1 to 2 of 2
    Default LTD LX production numbers
    As you can see, the total is not 3260. It is 5287.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Feb 2009
    Jackson, NJ 08527
    Shame, I have a blue 84 parts car, but it is a rot box.
    But thanks for posting, interesting for sure..................
