Results 1 to 4 of 4
    Default Front lower suspension bushings
    Haven't had much luck with the search, so here goes. What's the difference between a TRW 12408 and a 12408D? What is the significance of the D suffix in the part number?
    Thank you to all who answer.
    Don
    I believe the 12408 is the front lower control arm bushing and the 12408D is the rear front control arm bushing.
    Both of those numbers specify rear location on the front control arm. Front location takes 12356.
    Quote Originally Posted by PrecisionTrans View Post
    One of the sites I used didn't specify the position, so I thought that might be it.
    Worse case, order both and compare.
