Results 1 to 17 of 17
    Default Heater hose routing...
    Installing my heater hoses and the FSM really didn't show much...
    Its an 83, 5 liter, carbed...
    1. Looks like the 90 degree fitting faces towards the front of the car and the heater hose loops around then goes 180 degrees back to the firewall?? anyone make that a more direct fit as in aiming it more towards the firewall?
    EDIT: I think I have this one figured out.. It goes down in front of the valve cover than back.....
    2. The other hose just drapes on top of the valve cover?? And after looking at it, where in the heck does this one route around the alternator/alternator bracket?
    All of the engine bay pictures that I find have the Air Cleaner on and its hard to see the heater hoses...
    Thanks....
    Mar 2003
    Lowell, Oregon
    I ran one over the intake to the firewall and used an elbow or two to route the other down through the alternator bracket and to the firewall. Assuming non A/C.
    Route them how you want where you want.
    I can show a pic of what I did if you want.
    I thought about turning the elbow so it points towards the back and running the one hose under the fuel line ( there is alot more room than the pic shows) And I moved the coil to the drivers side strut tower.....
    Mar 2003
    Lowell, Oregon
    Not that it's the best option, but it is an option:
    I used the 90° to run the lower outlet down under the alt, to the fender well mount and up to the heater core.
    The upper I ran along the intake with a 90° in the back to get it to the heater core.
    When I get this new motor in I might try to run them both down and around.
    My hoses are shrouded in that red/black plastic hose covering.
    That 'coil' of wires surrounding the heater hoses at the firewall is the excess wire length for the O2 sensor for the FiTech.
    Richpet, thanks for the pics.....
    Mar 2003
    Lowell, Oregon
    No problem. Like I said, may not be the preferred routing, but I wanted the valve covers visible with as little crossing them as reasonable.
    Plus if I have to remove the valve cover I have far less in the way.
    Thanks....
    Both my heater core hoses drape across the pass side valve cover. That's the factory arrangement on my 85. But I don't think I have that 90 degree fitting there. Pretty sure mine is on the back driver's side of the intake. I don't know.... I need to look at it.... I may be confusing myself now.
    Edit June 24, 2023- My previous statement (in blue) was wrong! Not sure what I was thinking about, but I definitely have that same 90 degree fitting at the front passenger side of the intake manifold. At least I was right about confusing myself.
    Regarding how it routes behind the alternator and bracket, I'll try to get a pic of how mine is. Although it may not be accurate for an 83!? And I hopefully can post it now that I've got a picture-resizing-for-dummies tutorial.
    Jul 2009
    Chicago, south subs
    Gates makes a pre-formed hose for the connection to the water pump. It snakes around the alternator bracket and in front of the valve cover. 18917. The application is for 1985 Mustang, but it should fit any fox with the serpentine alternator tensioner bracket. I've got it on my 5.0 swapped '80 fairmont and '86 Ltd.
    Thank you..... Would you or anyone who has this hose installed on their car have a picture or two of it???
    Its not FOR dummies, its BY A dummy....... LOL
    Jul 2009
    Chicago, south subs
    Sorry, I don't seem to be able to share images.
    See if post #7 in the thread below is any help...
    http://vb.foureyedpride.com/showthre...43#post1952043
    Jul 2009
    Chicago, south subs
    no good. If I try to upload, I get 'upload failed'. If I copy & paste, it says I uploaded 24 images (?). I did resize them. Really small actually. Didn't help.
    Here's a couple of pics for ya....
    The first pic shows the hose after crossing across the top of the valve cover and turning 90° down the face of the end of the valve cover. It then turns 90° after it goes behind the alternator bracket.
    The second pic shows the third 90° bend as it turns downward (right at the 1F18 marking) after coming out from behind the alternator bracket. The last 90° bend shots it towards the water pump outlet connection.
    I used Gates numbers 18917 and 19839.
    Name:  230104_164838es - Copy.jpg
    Name:  230104_164812s - Copy.jpg
    Thanks to all for the help.....
    Attached a picture of what I did... I will use the gates prebent hose eventually and clean up the run ......
    I found a hole in the alternator bracket, under the alternator that I ran the one hose from the water pump nipple.....
    My goal is to start the engine, so working towards that now.... Yes the wires look bad, but I am not going to wrap any of the looms up yet until all is good...
    I did get the fuel line hard lined to my new carb, so pleased with that......
    I wanted to say here that I used the Gates heater hose from the water pump to my heater core and it cleaned up the routing of this hose and looks great.. So YES, it can be used on an 83 five liter....
