Hey guys. Hoping for some suggestions and advice. I've done a lot of searching (here & Google), and have found tidbits of information (some conflicting) but haven't found definitive answers.
I have an 84 LTD wagon with a seized 3.8. All systems (brake, fuel, etc) need work. It's been sitting a long time.
My end goal is to have a reliable driver powered by a stockish 5.0 with automatic trans. Budget is tight. And personal experience and knowledge is limited. So, low cost and ease of conversion would be preferable.
I was leaning toward the Lincoln Mk Vii option, because it seems to have everything I want on a fox body platform. So, I'm wondering what all I can use from an 88-92 Lincoln Mk Vii on my wagon. I'm assuming 5.0 HO engine and AOD transmission? Any chance the engine wiring harness and computer would be plug & play? Since the Mk Vii has an airbag suspension, will the 8.8 rear bolt in, in place of the 7.5? And what would it take to convert from 4 lug to 5 lug front and rear disc brakes from the Lincoln?
If it looks like the Lincoln is not the best choice, any recommendations on a budget minded option for a 5.0 swap into my wagon?
Any input is appreciated.
Thanks!
