Hopefully I posted this in the correct section.
Like the title says I just have a question or two! I'm going to be swapping my 2.3l 4cyl out with a efi 5.0 v8 preferably a 89-93 because of the mass air but I don't mind converting a non mass air year 86-88. So my question is what wiring will I need to make this work in a 82 mustang ( engine, body or dash)? The swap seems straight forward as far as needing 8.8, fuel lines, trans, cluster, etc.
I guess what I'm asking is will my 82 body, dash wiring work with a 86-93 motor? Obviously I know the engine bay harness will need to get changed and get a computer for mass air motor etc etc. Can't really find out that info or I'm just not looking in the right place.
Or if I buy a holly terminator x will this work with my stock 82 dash harness?
I also plan to buy a donor car so I'm not having to piece together fuel lines, fuel pump, rear end, trans, brake lines/booster, etc etc
