I replaced the automatic shifter bezel on my 1985 Capri and am having difficulty getting the knob/spring back on. Is there a trick to it?
I did that a couple of years back on my 79. Don't recall anything special todo.
To trigger my memory;
What is your issue with it?
Verstuurd vanaf mijn CPH2219 met Tapatalk
Don't think so, should just snap back on.
'86 GT - weekend driver
'86 Capri 5.0
'86 Turbo Coupe
'17 Mustang GT
'23 BRONCO
I think you may have the push button upside down.
When I attempt to reinstall the shifter T handle (with a spring loaded button) back onto the shaft, the button doesn't push in. The shifter T handle appears to be on but the button will not move. I've tried installing multiple times and same result. The shaft has a small roller with the cable attached to it and it goes over a v shaped channel down to the actual shifter link on the floor. The handle had to be pulled forcefully to come off and I have attempted to forcefully put it back on, but I've had no luck getting it right. I'm stumped.
I looked at that, but it appears that there is only one way for the button to be inserted into the shifter T handle...
I have found it was easier to slide on if I positioned the stick between gears so the little pill snapped bit was straight up and down. The as I press down I would push it out of that position.
You know what... I have a brand new extra I bought just in case. If you have problems finding one from a real reseller let me know.
Oh no... Sadly the motorcraft replacement is only the outer shell, not the button mechanism!
Here's a NOS A/T shifter button. Is it of any help?
https://www.npdlink.com/product/butt...0000%26year%3D
Wow. Surprised it's still available.
