Hello Im new here on this fourm. So I need help I have a 1985 5.0 auto cfi the car cranks but does not start. The car sat since 2006 and since receiving the car I did all maintenance work. I swap out spark plugs , wires , every fluid literally every fluid , new fuel pump , fuel filter & new fuel regulator. So I'm having fuel issue I just need some guidance on possible since this my first carb style vehicle mostly own efi foxbodies.
Anyways the car will start if I put fuel in the carb and once it runs out car dies. I disconnected the fuel line that connects to the carb and it does have pressure from the fuel. I noticed the injectors that are in the carb do not squirt out fuel when pumping the pedal. Any idea where I can check? It could be something simple thats going pass my head if someone can shine some light it be much appreciated.
