Results 1 to 4 of 4
    Default SVO Spring Specs
    Greetings!
    I am new to this forum. First post! Excited about interacting with you. I'm currently in the process of putting together a high end, extremely respectful SVO build. Had one back in '84 when I was just a kid (20). Actually had a bit of interaction with SVO back then via a high level marketing guy at FMC.
    Looking for Ford spring specs for H/HAX, G/ROS, N/POE, and R/POD. I'm sure many of you know the first letter is the spring code located on a door jam tag. E.g., 2HHRR. The HAXs and PODs are build codes. Don't have part numbers. Not sure if I need them. Just need specs - rates, etc. The SVO chassis guys sorted out the tune with Koni engineers plus a lot of track time. Lots of experimentation. Several combos made it to production if memory serves. I want new custom built springs using SVO specs. Can anyone point me in the right direction?
    Thanks!
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Welcome to the site!
    Maybe something to learn here?
    http://vb.foureyedpride.com/showthre...p-Spring-Value
    Mark Haas might have some info to share. Perhaps contact someone at SVPU? https://www.svpu.com/
    '85 GT
    The Official Ford Mustang 5.0 Technical Reference & Performance Handbook (pg. 376) says that each character in the four single-digit code character spring designation (i.e., HHRR) "is keyed to the coil spring's part number and spring rates. Translation keys to this coded data are published in each 1980-and-later Mustang's service manual; some are explained further in dealer literature."
    Looks like factory service manuals may have the info you're looking for.
    Appreciate that! DOES confirm the info I have. I'll contact SVPU.
