Results 1 to 25 of 31
    Default Valve cover fill and PCV pics needed
    Actually I am looking for pic of the oil fill cap and pvc cap
    I have an 83 5 liter car I am re assembling.. I believe I have the stock valve covers that came on the car...
    Unable to upload pics to this site.....
    Valve covers are cast with the ribs on top and " Powered by Ford" among the ribs...
    The hole in each of the valve covers have slots 180 degrees apart, and look like an old school oil cap with two " tabs" fit into and and tightens with a qtr or half turn....
    Drivers side hole will be forward and the pass side will back back by the firewall.....
    I am looking for any ;pics of the fill cap or PCV valve and the hoses and where they route to....
    Have the drivers side " fill cap" ( I think) and it looks like the hose goes to the air filter housing??
    Cannot find anything for the pass side hole that is towards the back of the engine.. I assume the cap has a hole in it with PCV valve in it.. Again sorry I cannot attach some pictures but this site will not take any of mine....
    Any pictures from anyone on here that could put me in the right direction??
    thanks for any help
    No idea if it's the same on my car, but same valve covers. Passenger has a fat pipe that goes to the air filter housing with a big sponge thing inside the housing. The driver side has a pcv tree. It only allows flow under specific circumstances. For the life of me I can't remember where they go but I am pretty sure it is the carb base. The is a CFI car though. I am sure a carb is going to be a little different.
    I would go look but a a couple thousand miles from it at the moment.
    Yeah, there is a rubber grommet that fits those that allows for the elbow to connect the hose to the air cleaner.
    E6SZ-6A892-A Ford PCV Valve Grommet
    The DS should go to the base of the carb and the pass should go to the air cleaner.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Jul 2010
    Houston (Clear Lake), Texas
    The drivers side goes to the carburetor base...I took this picture to show spark plug wire routing sometime bvck. The passenger side goes to the back of the air cleaner assembly...
    HAD
    HAVE
    Thanks.... OK, so the part I have must be the pass side that is drawing air in through the air cleaner ( I think ) ... The PCV must be on the drivers side, like in your pic.
    I have one other parts box to go look in to see if I have a twist on cap with the pcv valve now......
    Thanks to everyone here, this helps out..... Any pics of the pass side cap area anyone??
    Quote Originally Posted by Chuck W View Post
    Found my other twist cap.....
    The rubber grommets are different sized that push into these two twist caps... The metal twist caps are the same dimensions....
    The PCV valve grommet seems to be Dorman 42066.....
    No luck yet with the smaller grommet, that the 90 degree plastic angle piece pushes into that feeds off of the Air cleaner ( Passenger side)...
    The ID and OD are both smaller than the PCV grommet...
    See my new post in the 1984 5.0 PCV grommets thread.
    I've got the old 1980's vintage Ford Motorsport valve covers, not the stock ones, but I think the pass side didn't change any (unlike the driver's side which did change from stock). I'll see if I can get a pic tonight. If not, it might be tomorrow.
    I just read it... Thanks just what I needed......
    Broke the 90 degree angle fitting from the pass rear grommet... Any direction for a new one of those?
    Saw one somewhere. I'll try to dig it up.... may take some searching.
    And mine isn't a 90° fitting, iirc. Seem to remember it being a little more than 90°.
    I found a flaps replacement for mine. I can look closer when I get home if you haven't got it figured out by then.
    I think the way you have your spark plug wires is a clean and nice looking way to run them....
    My 83 has the same valve covers ( GT40P heads) with headers... My question is the bolt/stud/holder kits I see for sale say " 86 and up"??
    Is there a problem using these on carbureted cars, like ours?
    Jul 2010
    Is there a problem using these on older carbureted cars, like yours?
    My 85 GT vert has GT40p heads and Ford Motorsport stainless shorty headers. I used the stock valve cover bolts with studs that the plastic wire clips fit on. The clips and/or wires were a little tight given I'm also running the larger Ford Motorsport spark plug wires. I don't see a problem using this on earlier years given it was a stock setup for the 85 5.0L carburetor power plants...
    HAD
    HAVE
    I don't have a twist cap on the pass side valve cover on my 85 LTS.
    I swapped in those "Powered By Ford" Valve covers to replace the stock ones. That grommet I listed "twists" into the hole (had tabs on it) and accepts the elbow for the air cleaner hose.
    ( I checked and I don't have any pics of the current pass side set-up)
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Yea, that was my recollection too. Only the driver's side had a cap. The pass side just took a grommet right into the valve cover, for that elbow.
    Bentley - I got a pic of the pass side grommet, elbow and hose, but am having trouble posting it. Don't know why tho. Have asked for help here and will also try again later.
    Appreciate your help....
    I think I have seen pics of that grommet for sale, it has some " tabs" on the bottom... Are they what twist into the slots of the valve cover? Guessing that might work if the correct grommets for mine don't work out...
    Changes from 83 to 84 to 85 based on my parts search....
    My 83 has two twist caps for sure and those two rubber grommets that LMR sells seem to be what fits into my two metal twist caps..
    Summit has the plastic 90 degree ( at least it looks and the measurements seem to be correct) angle fitting for the rear pass side that is the intake for the PCV system via the Air filter.....
    All of my grommets and hoses ( and the plastic fitting I broke) are so hard and brittle they were a bee atch to take apart...
    My sister purchased this car in 84 and when it " stopped running" in the late 90's, she stored it inside so its in really good shape and its pretty much all oem... She did no alterations to it... ... I should add WAS oem......
    Only thing I found wrong was the clutch disc was blown up... The Crank and pistons are still in the original block, ( its getting an Explorer 5 liter) but I found nothing wrong with the engine so far.... BUT, I am going off topic now....... LOL
    Wish I could post some pics... Are the owners of this website ever going to upgrade it to accept a wider range of picture sizes??
    The fitting on mine broke too, so I just grabbed a straight one I had in the stash and used a length of hose to connect it to the air cleaner fitting.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Thank you for the pic..... Not at all like mine.... But I might consider updating to what you have...... I have to assume the grommet in your pic would work in my valve covers.....
    They're the same covers that you have, with the "tabbed" holes.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Jul 2010
    Bentley, I seem to recall the back passenger side setup is the same as the front driver side setup...being the black screw in type...on my original car. I did have to make my own gaskets for them when I went through the car years ago. If you look close at the picture I posted there is a metal hose connected to a short rubber hose coming off that front driver side PVC and the same at the carburetor base. The back passenger side is all rubber hose ending with a plastic flanged piece that connects to the back of the air breather...actually the plastic with foam filter piece inside...via a metal clip.
    HAD
    HAVE
    Yes, my parts all work out to be as you have described them.......
    After I found them and with all of help and pictures its coming together...... Thanks Everyone.....
    Here is a pic of my flaps fix.Name:  IMG_20230421_163945581_HDR_copy_768x1020.jpg
    Another request here... Which lower valve cover holes do the studs go into that hold the plastic wire clips..... Cleaned mine up today, seems as if I have 5 of them...
    thanks....
    This is how mine goes too I believe... I have two of the stock twist on caps as in post #4 on this discussion
    thanks, this will help with the Air cleaner connection.....
