Results 1 to 6 of 6
    Default GT fuel light on
    On my friend 1982 GT , the fuel light is constantly Even with full tanks ?
    Advice pls
    Low Fuel Warning Switch Circuit
    Improper operation of the low fuel warning system will be apparent when the indicator lamp remains On continually with more than 1/4 tank of fuel or if the indicator lamp remains Off when the tank is empty. If either condition exists, be sure the wiring connector is fully engaged in the low fuel module. Be sure the fuel sender connector is connected to fuel sender. If this does not correct the problem, proceed with the following:
    Disconnect the wiring connector attached to the low fuel warning switch. With the ignition On, test the terminal connector positions of the wiring harness connector as follows:
    Position 1: Blank, no terminal.
    Position 2: Connect a test lamp between terminal and ground. Test lamp should blink. If lamp does not blink, check the following:
    • With ignition Off, continuity should exist between pin two and the fuel sender hat terminal. If this is open, check wiring.
    • Fuel gauge inoperative: caused by open winding within fuel gauge.
    • IVR inoperative: If this occurs, no gauges function.
    Poistion3: With ignition On, connect test lamp between terminal and ground. Test lamp should blink and be brighter than position 2.
    • If test lamp does not blink, check IVR.
    • If test lamp works, but is not brighter than position 2, check wiring for open circuit between terminal two and hat side of the fuel sender connector.
    Position 4: Connect test lamp between terminal and positive battery terminal. Test lamp should glow and remain On.
    • If lamp does not come On, check for open circuit between pin four and ground.
    Position 5: Connect test lamp between terminal and ground. Test lamp should glow and remain On.
    • If lamp does not come On, check warning lamp fuse in fuse panel. If fuse is OK, check wiring between terminal five and warning lamp fuse.
    Position 6: Connect jumper wire between terminal and battery positive terminal. Warning lamp should glow and remain On.
    • If lamp does not come On. replace warning bulb.
    If all of the above tests prove OK, replace the low fuel warning module.
    Position 1: Blank
    Position 2: To Sender - Light Blue
    Position 3: IVR to Gauge - Black/Light Green Dots
    Position 4: Ground - Black
    Position 5: Ignition Switch - Red/Yellow Hash Marks
    Position 6: Warning Lamp - Yellow/Black Dots
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    The following link is pic of the back side of the dash, above the glove box. The low fuel warning module is the square black box, to the far right (far left from the front side of the dash).
    http://vb.foureyedpride.com/attachme...1&d=1636432374
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    They are not the easiest to find.
    I found this one ebay last year when mine stuck on.
    NEW - OEM Ford E9AZ-9F326-A Low Fuel Level Warning Switch Assembly
    Mine does that every now and then.
    Most of the time it goes out after a few miles.
    Other times opening the glove box and gently wiggling the wires up there by the light switch works.
    Dunno why.
    There is a wire behind the gauge cluster that needs to be plugged in too. Easily missed when reinstalling cluster.
    Thanks for the link to that. May have to pick one up just to have as a spare. Seems like the kind of part that would no longer be available if the time comes that I ever needed one.
