This is kinda dumb, but want to be sure.
Pretty sure I am loosing a small amount of coolant from the intake at the rear of the engine. Coolant levels go down slowly, and I have a small amount of smoke coming from the rear of the engine. Planning on the next month to do an exploratory surgery on it by removing the upper and looking.
However....if I go ahead and replace the gasket on the lower....I know to clean everything, and surface prep is key. Then....do I put silicone, then the gasket, then MORE silicone before installing the lower? Or....just silicone, then the gasket, then the lower?
Thanks guys!
