Results 1 to 10 of 10
    Default Correct battery placement in a 83
    Installing a new battery tray and the new OEM negative cable is installed... When setting the battery in the tray it looks like all of the battery cables line right up if the battery is set with the two poles next to the fender rather than the engine side, as I assumed was the right way?? Nothing in my FSM to guide me.....
    I also assume the positive cable went UNDER the air intake hose ( from the fender to the air cleaner,) but again, the ( what I think is an OEM Positive cable) seems to fit perfectly going over the top of the intake hose????
    Can anyone help me here?? Thanks
    83 vert, 5 liter, manual........
    Poles to the inside. No clue about original setup for the cables. My ground goes under. My positive goes over but it isn't original.
    Cables to the inside. Water and snow can get down the hood gap and onto battery terminals the other way around.
    On my car, battery is on the pass side. Requires a battery group size ending with an ' R' for correct battery terminal placement.
    The truck battery is on the ds, not an 'R' battery. R means reverse terminal config.
    The cables route factory correct on both vehicles. both have the + terminal to the rear and the start solenoid.
    Ok.... If installed with the two poles towards the engine, my Neg cable does not reach.... I will try to find a different place to attach it to the engine...
    The pos cable, from the relay, would go under the Air Cleaner hose then....
    Thanks for the help, I will fool with it some more.....
    So with the water getting on the bat terminals, if facing towards the fender, would the concern be the water shorting out the battery?
    Yes, like emerygt350 and gr79 stated, the battery terminals go to the inside.
    And both battery cables do go underneath the air cleaner intake hose, in a from-the-factory arrangement.
    First I've ever heard about the battery group size needing to end in an "R". The Motorcraft BXT56A battery has the correct terminal placement and it is listed as a Group Size 56, without any kind of "R" designation.
    https://www.oreillyauto.com/detail/c...-mustang?pos=0
    Default r or no
    Note were the red + terminal is.
    If the battery is made to install on the opposite side of engine bay, then the cables wind up on the fender side of battery.
    Cables may not reach unless battery is turned around.
    If not aware of the difference, the cables may not route right.
    This is the one i use in the Mustang, only a 96R not a 40R.
    Passenger side location
    Many newer Fords use an xxR battery.
    My Ranger is not an R battery, location is drivers side. BXT-65 no R.
    Ok. I understand all that. I agree that in your examples an 'R' suffix is applicable.
    My comment was more directed to your statement "On my car, battery is on the pass side. Requires a battery group size ending with an ' R' for correct battery terminal placement." I was just pointing out that there is at least one battery (the Motorcraft BXT56A) that does not have an 'R' designation, and that was designed for passenger side mounting on a foxbody.
    Interesting? I just put a BXT56A in my 86' and it's on the drivers side. The positive cable is further towards the front of the car and the negative the rear.
    I'm sure this doesn't help or pertain to the original post, but just throwing it out there.
    1986 Mustang GT - 2A, 5 Sp
    2018 Subaru WRX (Daily)
    Where'd you get yours at? Ford or a parts store?
    And was that the terminal positioning on your previous battery?
    That BXT56A is the battery that comes up as the O'Reilly's recommended one for both an 85 and an 86, even though they're mounted on opposite sides of the engine bay. That's a little odd to me. For some unknown reason, I always thought the positive terminal was positioned to the rear. That may have just been me inventing a reason though.
    Availability may also be a factor in O'Reilly's choices. Not that they are any kind of expert anyway.
    Ordered it from parts.ford.com and picked it up from a local dealership
    Terminal positioning was the same, it replaced some weird off-brand called called Sure Start(?)
