Results 1 to 6 of 6
    Cool door hinge pin set
    Any one have the part # for the pin kit for an 2001 mustang?
    St. Louis, MO.
    I replaced the ones on my 99 with these......
    https://lmr.com/item/LRS-BP7SN-K/Mus...pair-Kit-94-04
    Scotty
    Past Pony's.....
    are these the same as the 79-93 dorman 38395 pin kits where they longer than they needed to be?
    did the bushings go in the hinge with out having to resize at the hinge
    St. Louis, MO.
    I don't think those will work because I bought that Dorman set at AZ for my 88 but when I looked up the 99 AZ had none listed that's why I went with LMR.
    Fitment was fine and the bushings tapped in with no problems.
    Scotty
    Past Pony's.....
    St. Louis, MO.
    They look the same but have diff numbers......
    https://lmr.com/item/LRS-BP7-K/79-93...hings-Set-Of-4
    Scotty
    Past Pony's.....
    they where the same /close to the stock pins length
